Учебники
Файлы ресурсов
Требования
RailClone 6 Lite or Pro
Рекомендуемые продукты
Получить продуктыRecorded on Tuesday 30 May 2023, this special livestream Q&A session explains nearly all the new features of RailClone 6, including:
- 00:03:15 Introduction
- 00:05:19 New Libraries
- 00:11:46 how to use the always-on-top style editor
- 00:15:44 RailClone Basics and the new RailClone Slice modifier
- 00:36:22 how to quickly add your custom RaiLClone styles to the library
- 00:39:40 How to use the improved Group features
- 00:48:00 Style Editor Improvements
- 00:49:11 How to control automatic segment naming
- 00:50:20 How to assign geometry to multiple segment nodes
- 00:52:00 How to clone nodes using shift+drag
- 00:55:20 How to automatically convert scene objects to segments
- 00:58:00 How to choose between open and closed doors using a Selector node
- 01:00:20 new marquee select options
- 01:01:17 New value list node
- 01:03:26 How to change the thickness of wires in the Style Editor
- 01:03:45 Boolean AND/OR in conditional nodes
- 01:04:50 Using Link and Reroute nodes to organise graphs
- 01:09:18 How to convert an existing graph to macro
- 01:12:16 Saving presets for drop down lists
- 01:13:50 How to limit generators using comma separated lists or ranges of material IDs
- 01:17:06 New segment and number randomisation options
- 01:22:46 Using the new new Free marker type
- 01:27:45 Using deformation modes on segments below the X Spline
- 01:33:35 How to password protect RailClone styles
- 01:35:23 How to UV map and assign material IDs to capped faces
- 01:37:39 How to assign user attributes to instances distributed with RailClone
- 01:40:33 Outro and invitation to the next webinar
