Учебники
Файлы ресурсов
Требования
Forest Pack Pro
Рекомендуемые продукты
Получить продуктыWelcome to our latest tutorial exploring Forest Pack’s built-in Effects. This time, we’ll explain a really handy option that allows you to automatically rotate objects scattered with Forest Pack so that they face down the slope of a surface.
It's very simple to use. To add the Face Downhill Forest Effect, go to the Effects rollout and click + to add a new effect. Click the wand icon to open the Effects browser and then select and load the Face Downhill effect from the Transform folder.
That’s it! The effect uses the surface normal of the polygon under the scattered item to determine the direction of the downward slope and aligns the object accordingly. If you do want a bit of randomisation on top of that, you can use the AngleMin and AngleMax parameters.
As you can see, it takes just a few seconds to add this effect in Forest Pack, but it could save a lot of time manually rotating individual objects. Remember, this is just one of the many effects included in Forest Pack and we’ll continue to release more tutorials covering others, so stay tuned and please feel free to let us know in the forum if there’s a new effect you’d like to see added!
