Tutoriales
  • Inicio
  • Tutoriales
  • Using ParametricLibrary All-In-One Background Building Presets
How to use the all-in-one building presets including in our ParametricLibrary Background Buildings collections.
Recursos
Requerimientos
RailClone Pro
  • Logotipo de RailClone
  • Recursos inteligentes para construir mundos mejores
Capítulos
In addition to 13 fully parametric individual towers, the collection also includes an all-in-one preset that's designed to quickly and efficiently fill large areas. To use it.
  1. Create a new RailClone object and open the Library Browser. Select and load the All-In-One preset..
  2. To edit the object, all the settings can be found in the Parameters and Base Objects
  3. The most important settings are the X and Y size parameters which allow you to specify the grid size of the buildings
    It's also possible to use a spline for the X axis should you need a layout that follows a straight or curved path. 4. Information about the presets many other parameters are shown in our documentation.
