Tutoriales
How to use RailClone 6's always-on-top style editor
Learn more about the new features in RailClone 6's style editor
Tecnologias:
RailClone
Rutas de aprendizaje:
Learn what's new in RailClone 6
Recursos
Requerimientos
RailClone 6 Lite or Pro
  • Logotipo de RailClone
Capítulos
RailClone 6 Introduces the always-on-top Style Editor, a new feature that streamlines your 3D modeling workflow.
Now, you can keep the Style Editor open even when you deselect the RailClone object. This allows you to simultaneously edit styles and related scene objects, making it easier to modify the source geometry, tweak the base splines, and work on other aspects of the scene without losing access to the graph of the last edited RailClone style.
If you want to see the graph for different RailClone objects, simply select it and click its 'Open Editor' button. The open style editor will switch to the new object
And if you’ve deselected the RailClone object to edit something in the scene. You can easily reselect it again using the new button has also been added to the Style Editor toolbar to select the active RailClone object.
With the always-on-top Style Editor, editing your 3D models has never been easier.
