Author Topic: RailClone Lite/Pro 1.2.0  (Read 13412 times)
« on: June 05, 2011, 03:09:46 PM »
VRay Mental / Mental Ray support
RC120
Added geometric shaders for VRay and Mental Ray, letting you to render a huge number of high-poly objects using minimal resources:
  • Create massive railing and structures over paths as long as kilometers.
  • Objects are converted on the fly to native render instances.
  • The geometry is generated dynamically inside the camera frustrum (VRay only).
  • VRay Proxies and mr Proxies are supported.
Note: See Rendering Best Practices to learn more about the geometric shader and how to optimize your scenes to use it efficiently.
Display
A new Display rollout has been added:
  • Configurable "Boxes" mode for Viewport and Render.
  • Adaptative mode. Use "Boxes" mode on viewport if the number of faces specified is exceeded.
  • "Boxes" display mode is more accurate respect to the full geometry.
  • Render mode: Automatic mode uses native instances for VRay or Mental Ray. Meshes mode creates a unique mesh for the geometry.
  • Build button and Max.Faces and Max.Segments parameters have been moved from the General rollout here.
Other features
  • CPU Multi-core support. Global performance have been improved.
  • Randomness->Mapping Coordinates. Avoid texture tiling, applying box mapping to the Segments along the path.
  • Added Max 2012 support.
Fixes
  • Fixed geometric issues when applying both random rotation and scale.
  • Bevel works properly on splines with collinear vertices.
  • Geometry->Copy From/To works properly on RailClone objects with modifiers.
  • Fixed minor Library Browser issues.
« Last Edit: June 06, 2011, 09:45:16 PM by Itoo »
